Chugging noise low rpm
Cbuts05
Bought an 08 ram 1500 slt two months ago.
Ever since I bought it I've had this chugging noise at low speeds or going around corners ONLY around 14-1600 RPM
Since I bought the truck I've done the follow.
Plugs
Tranny pan kit
Pcv valve
Egr valve
Crank and camshaft sensor
Map sensor
Cleaned throttle body
The chug doesn't happen below or above those rpms.
Please help the dealer wants 220+ just to figure it out .
RonJon '06
Southern Minnesota
It might just be the MDS kicking in, it can make a kind of drone sound out of the exhaust.You could try disabling the MDS by putting it in Tow/Haul mode and see if the noise goes away.
C
Cbuts05
Will give it a try and report back thanks for the reply
C
Cbuts05
Yes ! Putting it in tow haul made it barley even noticeable ...
Now what can I do to make it go away without this tow haul lol.
justin13703
MD
Get a tuner and have the mds shut off.
blackbeautyhemi
Lewistown, PA
Around $350-400 depending what brand and it'll give ya a good power boost and a couple more mpg's. I recommend diablosport.
MADDOG
Out Exploring Arizona
Contact Matt at Moe's Performance. He'll have just what you need for a programmer.
Custom tuning is also available and I highly recommend you discuss that with him as well.
blackbeautyhemi
Lewistown, PA
Ok maybe I'll go with that ..can u recommend which one
The Diablo intune will work great and can do custom tuning, the trinity model isn't necessary unless you wanna monitor things as you drive. As maddog stated Matt at moes will get ya hooked up with what ya need.
