Differential lubricant recommendations
usocazy
San Antonio, Texas
Hemi 5.7l
Looking to change the lubricant in my differential this weekend. 2004 Dodge Ram 2500 2WD.
So according to my Haynes manual, it says to use Mopar Synthetic gear lubricant SAE 75W-90.
Can I use any gear lubricant so long as it's 75W-90 weight? Based on my year, I don't need to add limited slip differential fluid, correct? Is one 32 ounce bottle enough?
Autozone has a bunch of SAE 75W-90 weight lubricants so I'm investigating my options.
usocazy
usocazy
San Antonio, Texas
Hemi 5.7l
Well, guess I'll just run any 75W-90 gear oil and hope for the best. [emoji12]
Found the fluid amount on the next page of my manual. Helps to read stuff fully from time to time.
xtremewlr
Tucson, AZ
2004 hemi, you should have the LSD rear end and therefore should add the LSD fluid. Comes in a small tube and you add it to the gear oil. Assuming you have the stock gearing and LSD still.
Scratch that, I scrolled up and saw you have a 2500. Looking at the owner's manual, the 2500 uses the 75w-90 and does not require the LSD additive. My bad.
2500/3500 Model Front and Rear Axle
Synthetic, GL-5 SAE, 75W-90. Limited-Slip 10.5/11.5 inch Rear Axles DO
NOT REQUIRE a limited slip additive.
xtremewlr
Tucson, AZ
Fluid Capacities: REAR AXLE ± .03 L (1 oz)
9 1/4 - 2.32 L (4.9 pts.)*** With Trac-Lok add 118 ml (4 oz.) of Limited Slip Additive.
10 1/2 AA - 2.25 L (4.75 pts.)
11 1/2 AA - 3.62 L (7.65 pts)
usocazy
usocazy
San Antonio, Texas
Hemi 5.7l
Thanks for the confirmation. It's always good to have a second set of eyes on things. [emoji102]
usocazy
usocazy
San Antonio, Texas
Hemi 5.7l
Having the hardest time finding a gasket for my differential at a decent price. All I'm finding is one at Rock Auto for about $30 shipped. Is that the going rate? I've got a 10.5" differential.
MarshRam
Florida
2014 SLT 4x4, 2012 ST
You can always opt for some rtv gasket maker. Just pulled my diff yesterday, it had rtv on it from the last change and I used it again.
usocazy
usocazy
San Antonio, Texas
Hemi 5.7l
I was thinking about possibly going that way. Thanks for the input. If my cheap gene keeps kicking then I may opt to buy a tube of RTV and call it good. [emoji12]
MarshRam
Florida
I would say the only downfall is cleaning it off the next time you change. Not a huge deal, but a little extra work. Otherwise, seals fine so long as the bead is good and you press it back on without moving it around. Easy to do with one of the top and bottom bolts to guide you in.
usocazy
usocazy
San Antonio, Texas
Hemi 5.7l
Wound up getting a good gasket from rock auto for only about $20 with shipping. Replaced the gasket and fluids this weekend. Also painted the differential cover black for a little color under there besides all the road dirt colors that currently exist. [emoji1303]
Bullitt5339
St Pauls, NC
I never use the gaskets in any of my vehicles. They're prone to leak even more than just using a good black RTV.
ST-8
I didn't even know they came with a gasket on the diff cover lol, I've had the diff cover an trans pan off multiple times an used black rtv an it was g2g. Like bullitt said above I'd be more worried about the gasket leaking.
JPT
NY
2015 Big Horn
deleted.
