1SLwLS1
- Jan 8, 2013
- 199
- 244
- 2013
- Hemi 6.4
For the last few thousand miles, I have noticed a whining/growling noise. It happens under acceleration/coasting/deceleration from 20-140 MPH (haven't driven faster). The noise does not change with load nor engine speed, it only changes with wheel speed. The vehicle is a 2013 Ram 1500 4x2 with MMX SRT 392, 8HP70 swap (SGA), 3.92 OEM limited slip rear differential, and over 200K miles.
At first I was leaning toward rear differential as I have been somewhat abusive lately with fish-tailing and rough maneuvers. The fluid that was in it was Red Line 75W-140 changed about 2 years ago with 30K-35K miles. I was also thinking it could be transmission related (output shaft) as anyone who has seen my posts on the 8 speed swap thread knows, my used transmission was flooded and filled with nasty cheese prior to installation - I did my best to flush everything out but who knows. I then stumbled upon a wheel bearing video yesterday and the noise this 4-runner made was identical to the noise I was hearing.
Last week in a pinch, I replaced the differential fluid with OTC Valvoline synthetic 75W-140 (both new and old fluid have friction modifiers). I did not see any magic sparkles in the fluid and the drain plug looked relatively clean, see below. I also topped off the transmission fluid which took only a pump or two, so it was still full (level using the green ZF procedure). Last night I did the spin test and grabbed the wheels at 12:00 & 6:00 to test wheel bearings. This is my bet, rear wheel bearings. I also inspected the central driveshaft support bearing. The movement did not seem excessive and the rubber seemed compliant, this did not appear to be the culprit.
I did not want to fire the parts canon but with rear bearings only costing $20, that is the direction I am leaning. Thoughts?
Forgive the vertical videos, I only had the thought to record as I was doing the tests and I used my giant jack stands to support the phone.
Here is the noise loaded, driving down the road:
Here is the noise unloaded, stationary on jack stands:
Here is the rear axle spin test, this is my bet:
Here is the front spin test, I may have a sticking caliper slide-pin/bolt on the right front, but no real noise:
Here is draining the rear differential and condition of the plug:
Whine/growl noise 2013 Ram 1500 - Driving down the road
Part of video series to help diagnose whine/growl noise.This video shows the noise upon deceleration and acceleration with rear end loaded driving on the road.
www.youtube.com
Rear axle noise, possible wheel bearing
Part of video series to help diagnose whine/growl noise.This video shows the noise of the rear axle spinning both left and right rear wheels.
www.youtube.com
