I really don't believe so. I'm pretty sure 4x4 use a coil over while 4x2 use spindles, coil springs and shocks (which is why you can't use bilstiens on 2wd)
The frame is the same for the 4x2 and the 4x4 though. Damn good question. Welcome to Ram Forum.
Will the struts off a four wheel drive work on a two wheel drive, i noticed the frame has the holes for the struts.
