I thought I might revive this old thread with a write up about my new shifter.
A few weeks ago I installed a Hurst short throw shifter in my 2006 Ram 1500 with the Getrag 238 manual transmission. I bought the kit from a company in Tennessee called Core Shifters. They build custom shifters for many different applications with a combination of Hurst components and parts they manufacture in-house. It came with a pre-assembled shifter base, Hurst chrome plated stick and Hurst knob. The instructions were clear, detailed and easy to follow. I thought I would write up a few tips and share my thoughts.
The shifter kit from Core Shifters is for the 2005 - 2008 Ram 1500 with the Getrag 238 6 speed transmission. Core Shifters also offers shifters for other years as well. There are a few shift knob options, I chose the classic round black knob. Core Shifters builds and assembles the order after it’s placed, so it took about a week and a half to receive. The price was $260, with shipping additional.
The hardest part of the install was removing the factory cap from the shifter knob because I didn’t know how it was installed. I finally dug it out of the knob with a small screw driver, after ruining the cap and scratching the knob. It's not a small cap that pops off the knob, it literally sits in a small groove down inside the knob. I had to make 2 trips to the auto parts store for 2 different sockets that I needed - an E8 external Torx and 7/32 hex socket. The E8 socket is needed to remove the factory shifter base from the transmission. The 7/32 socket is needed to install the Hurst chrome stick to the new shifter base and torque the bolts. I have allen wrenches, but wanted to use a torque wrench. I also applied blue threadlocker to all the hardware before torquing.
I reused the factory shift boot with the new Hurst stick, but didn’t like the way it looked. I purchased a Hurst shift boot grommet from Core for $14 that fits over the stick and has a groove for the shift boot to set in. The factory boot is made from rubber so I used a plastic bicycle tire tool with a hook to pull and stretch the boot over the grommet. The shifter now looks more finished and the boot doesn’t slide up the stick.
The Hurst stick is used with several different kits, so its design isn’t exactly the same as stock. The knob height is the same, however its position to the driver is not. The angle of the stick is not as steep as the factory setup, so the shift pattern is farther away from the driver. It’s not uncomfortable to shift, my arm is more out stretched than before. The shifter base pivot is shorter, which makes each shift noticeably shorter. I’m planning a few performance upgrades to my truck in the near future and wanted a short shifter to give it a sport truck feel. The SRT Ram comes with a Hurst shifter and I was curious if a similar upgrade was available for the other Rams - a simple Google search brought me to Core Shifters.
Overall, I’m very pleased with the Hurst shifter. The internal mechanism of the factory shifter base is built with a lot plastic to reduce noise and vibration, but it caused the shifts to feel very spongy and loose. The Core Shifter base is all metal construction and each shift is definitely more solid and precise. Shorter throws, firm shifts and classic styling of the Hurst stick and knob are the reasons why I’m very happy with this purchase and recommend it to everyone with the manual.
I know this post is lengthy, but I wanted to provide my experience to potentially help any other manual trans owners who wish they could upgrade their shifter - just like I did.
This is how the shifter looked after I first installed it:
Here's the final install:
