archerr2002
- Oct 2, 2011
- 60
- 1
- East Liverpool, Ohio
- 2006
- Hemi 5.7
Rear was leaking on the passenger side. I got the new inner seal and the axle gasket and tore into it. Took it all apart and got all the oil cleaned off everything. The old seal did not look bad. Bearings were in great shape. Put the new seal in the hub and started reassembly. I had trouble getting the new seal to slide on the axle but finally got it on. Slid the drive shaft back in with the new gasket and put thread lock on the bolts and tightened them down to 95 ft lbs as per the manual. Topped off the pumpkin (1" below the filler hole) with 75w 90 full synthetic. The damn thing started leaking again after 3 days. Any ideas?
