I know this is an old thread, but I'd like to chime in on it, and also see what you decided to go with, if you have purchased..
I run an '01 QCSB 2500 CTD 6speed with a 96" Arctic Poly (HD96-P) and it does fine. I try not to beat the hell out of the truck with it, but sometimes you can't keep from it. I have several contracts and have no issues in using this plow setup. The 6speed, however, is another story. 4-6hrs of plowing, and I think I could possibly kick a mule over with my left leg; especially, with the 3600lb SB dual-disc setup.
Make sure you check/tighten all the fasteners at regular intervals. Keeping them tight will help slow the destruction of your truck.
I have to carry about 5-600lb in the bed, just behind the rear wheel wells, and needed Timbren overload bumpers on the front end to carry the weight. I wished my plow was a little taller, but it does just fine, provided I don't get a late start and there's 8-10" on the ground. I usually hit the snow about the 2" mark, as that's what most of my contracts are written for (I do have a couple zero-tolerance ones, which are nice money-makers.)
A V-Plow is too much weight on these front ends, IMO. I'd LOVE to have one, but the front will squat a lot just picking up the 8' poly straight-blade.
Hooking/Unhooking the Arctic QCII is as easy as pulling up to it, connecting two pins, 3 Packard style connectors and one battery power connector. Takes me like 1 minute to hook.
Joystick is another Packard connector, and I've made a panel that fits under the armrest and sets the controller just between 2nd gear and the console. Perfect, IMO.
And the diesel loves to work. I can plow for 6hrs straight in 8-10" of snow, and use less than 5 gallons of fuel. Try that with your gassers, fellas
(just pokin' fun)
My '02 4.7 won't even idle for 6hrs on less than 10 gallons, I think LOL It's a pig on fuel...
--edit--
As a side note:
The Hiniker 8' scoop plow is 770 lbs, 30" tall. My Arctic 8' plow is 30" tall and 130 lbs lighter, yet the mold board is 3/8" thick, vs. Hiniker's 1/4" mold board.
Remember that the scoop plow is not movable, like a V, although it is a power-angler like a straight blade.
