sdamike
- Feb 4, 2013
- 26
- 0
- 2015 and a 1999
- 5.7
So I recently bought a used 04 ram 1500 with the 20" factory rims and tires on it from a dealership and from the get go i hear a low speed maybe 5-15 mph rotating noise (and a little vibration not much but its there)...Im thinking its a wheel bearing noise but it seems to go away at higher speeds...is that just tire noise? (thats what they are telling me)
I also have a random suspension clunk going over bumps, but only over certian bumps. It sounds to be in the front end but for the life of me I couldnt tell you if its passenger side or driver side. I complained and they took the truck in and Supposedly the front upper driver control arm was changed and nothing else was found loose in the front end. I still hear both noises and they dont know what to tell me. Its 10 degrees out with about a foot of snow on the ground so I cant jack it up and investigate for myself. Any common culprits there?
Sorry if these are dumb questions, its my first full size truck so im alittle lost on what is normal noise. Thanks for the help!
