nigthrunner
- Feb 17, 2014
- 4
- 0
- 2006
- hemi 5.7
I was replacing broken spider gears and decided to replace the pinion seal while I was down there. Now I am stuck on the pinion nut torquing. I know the subject has been beat to death, but I am looking for opinions for the next step in my situation.
I did not have an in/lbs torque wrench to measure the force needed to spin the no-load gear set nor do I have access to one (loaner).
As I seen on a youtube video-I marked the nut and bolt, counted threads and counted turns to remove the pinion nut. Upon reassembly, it went back fine, but I am concerned on if there needs to be more/better torquing? I checked it with my torque wrench maxed at 150 ft/lbs with no click and stopped when the nut/bolt marks aligned. So it is well below the spec'd 210 lbs. The thing is I bought the truck with 24K miles on the clock, it has 81K now, the nut/threads had surface rust and appeared not to have been messed with before, I put it back together as marked/counted, there is no movement except normal rotational slack and appears/feels normal. I also used blue lock tight.
Do you think it will be fine or what should be done?
Other possible/questionable factors are the diff cover and pinion seal had orange sealant used (is that factory or signs it was cracked open before I bought it?). Also, I did not notice lock tight when I took the nut off.
thanks for your opinions/input.
