Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Lowered
Lowered
Going lower soon!
This is a discussion on Going lower soon! within the Lowered forums, part of the 3rd Gen : 2002 - 2008 category!
Like the title says I'm going low soon. Was gonna lift it but its a 2wd and just didn't wanna ...
Like Tree2Likes
Reply
Old 09-24-2016, 03:44 PM   #1 (permalink)
Ram Year: 2007
Engine: Hemi 5.7
Default Going lower soon!
Like the title says I'm going low soon. Was gonna lift it but its a 2wd and just didn't wanna do it. also the truck wouldn't fit in my garage then. Always lowered everything i owned and guess I'm gonna stick to my roots.
Anyways, I am going with the McGaughtys Deluxe 2/4.5 kit as I want zero issues with front end geometry. The only problem I think I'm going to run into is my tire size. Right now I'm rolling on stock 20" wheels with stock size tires. How much rubbing will there be with that setup or is it even possible? I don't mind hammering the fenders or trimming a few things. But the tires I have are pretty new with maybe 2k miles on them. My goal is to run 22" dub ballers with this drop.
Any insight will be helpful! Thanks guys!
Sponsored Ad
Register to remove this ad.
14blkbeast is offline   Reply With Quote
Old 09-24-2016, 04:07 PM   #2 (permalink)
Ram Year: 2004
Engine: 3.7
Default
With the Deluxe kit, you won't have any front geometry issues because it uses spindles only for the front drop.
Your wheels and tires won't be a problem with that drop either. I think 22's will fit with your drop no problem as long as you get the right tire size to stay close to the factory tire diameter and don't go stupid with the offset.
Here's mine with 22's, although mine is just a little bit lower than you're going.
Tray Burge likes this.
Bullitt5339 is offline   Reply With Quote
Old 09-24-2016, 06:58 PM   #3 (permalink)
Ram Year: 2007
Engine: Hemi 5.7
Default
Thats great to hear.
What offset am I looking for when going with the 22s? And possible suggested tire size?
Old 09-24-2016, 07:31 PM   #4 (permalink)
Ram Year: 2004
Engine: 3.7
Default
Mine are 19mm, same as the stock 20's.
305/40/22's is the stock tire size for an SRT-10, that would be a good starting point.
Old 09-26-2016, 09:48 AM   #5 (permalink)
Tray Burge's Avatar
Ram Year: 2003
Engine: 5.7 Hemi
Default
I used the same kit and I have 22", no issues at all. I did have to upgrade to performance shocks to keep from bottoming out, but you probably already knew this.
__________________
"Real men carry steel guns, plastic's for squirt guns" -Jeff Cooper
Tray Burge is offline   Reply With Quote
Old 09-29-2016, 02:50 PM   #6 (permalink)
Ram Year: 2007
Engine: Hemi 5.7
Default
Oh i knew the performance shocks were a must. Never have I lowered a truck without installing appropriate shocks. Mine are shot anyways. Truck rides like sh**.
So here is another question...what if I wanna go with 24s? I know the front will probably need some cutting in places. Very prepared to do that. But what width and offset would I be looking to fit them and possibly do a 4/7 drop?
Already ordered the 2/4.5 kit. Just gonna start there. Not going lower until I decide what I'm going to do as far as wheel size.
Old 09-29-2016, 02:53 PM   #7 (permalink)
Hemi450hp's Avatar
Ram Year: 2011 Ram 1500
Engine: 5.7L Hemi
Default
What year is your truck? Your profile says 2014, but this is posted in the 3rd gen section. That will determine what you will need to achieve the drop you are looking for.
__________________
2011 Ram 1500 - 11.99 @ 110.66MPH N/A
2011 Ram 1500 - 11.09 @ 120.13MPH Nitrous
2014 Ram 1500 - 12.38 @ 109.61MPH N/A
Hemi450hp is offline   Reply With Quote
Old 09-29-2016, 03:51 PM   #8 (permalink)
ST-8's Avatar
Ram Year: 2004
Engine: 5.7
Default
These damn 4th an 2nd gen people always up in us 3rd gens space.
usaf2006 likes this.
__________________
2004 Dodge Ram 1500 ST- 5.7L RCSB
SC 3865- Comp 260- 6.1 springs- 6.1 pushrods- Pacesetter coated LT's- Bfi #42- 4.56s- oem lsd unit- junkyard 4.7 trans an converter- 3/4.5 drop
ST-8 is offline   Reply With Quote
Old 12-08-2016, 08:10 PM   #9 (permalink)
Ram Year: 2007
Engine: Hemi 5.7
Default
Sorry guys the truck is actually a 3rd gen. My last truck was a 4th gen. Need to update my profile. Sorry about the mixup.
So I have actually decided to go with the 4/6 drop on the truck. Might as well go as low as I want right off instead of gradually doing it. The only problem with that is will the stock 275/60/20 fit with that much of a drop or am I gonna have to change the tire size? A little rubbing never hurt anyone and I'm good with a hammer. haha The tires will change soon enough just wanted to know if the stockers will work for the moment with minimal issues?
Thanks guys.
Old 12-08-2016, 09:05 PM   #10 (permalink)
ST-8's Avatar
Ram Year: 2004
Engine: 5.7
Default
I was just being an asshole, 4/6 will deff rub with that tire size.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
A Little Lower TRXHemi Lowered 22 04-13-2016 09:20 PM
Want to go lower ahamel11 Lowered 6 02-06-2016 11:52 AM
replacing lower ball joints aftermarket lower arms Tylermar Lifted 3 04-05-2015 10:57 PM
replacing lower ball joints aftermarket lower arms Tylermar General Discussions 0 03-30-2015 10:29 PM
OEM lower air dam. NWRQC Wanted 2 10-26-2012 05:24 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
