Leaf springs
TheMaddog
DFW
Alright, Ive seen it done, but I forget what the name of the clamp is called, it's to put your leaf springs under your rear axle, and would anyone know how low it's gonna go? I need to match the front but I dont know what I should do to the front.
TheMaddog
TheMaddog
DFW
Yeah, how much do those run?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Ya might want to start with a set of drop shackels though alot cheaper.
Looked at 3rd strike and said 02-06... might wanna shoot Duane a PM
glass3222
Central PA
Flip kit will get you about 5" of drop in the rear. It is not a simple bolt on kit. You will need new spring perches and they have to be welded in at the correct location so everything stays aligned.
HemiBabe
DFW
^^yes, I dont know if you can buy them seperately from the entire drop kit or what. The drop shackles do not provide enough drop to me, it barely differs from stock. I have pics of mine stock, with 2" drop shackles, and my sig is the 2/4.5 with the flip kit. If you dont weld them and just bolt it on, it will eventually get loose and could be a disaster. I can take a pic of what my flip kit looks like if you would like
TheMaddog
TheMaddog
DFW
Will do. Thanks
TheMaddog
TheMaddog
DFW
Yes. I would live you see what it looks like, and my cousin is gonna do all the leaf spring stuff. He did everything to his bronco. 4 inch body lift with re torqued leaf springs. And I think we're gonna do both, just for ***** and giggles so things will stay.
HemiBabe
DFW
Okay, here's the pics of my flip kit. I have it bolted and welded on both sides of the perches.
If you want any other pics of it, lemme know I can go right outside and take them
TheMaddog
TheMaddog
DFW
Perfect. How big are your rims. I'm about to show the 'rents your car and say this is what I want. But blue and black.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Think hers are 22s. Deff get the perches welded so you don't have axes wrap and lose a driveshaft.
icywhite
hey you could always have the spring professional dearched which are how mine are and i have a 4.5 drop in the rear and i have that on 24s with no real issues
icywhite
oh yeah bump stops are going to have to replaced or cut
TheMaddog
TheMaddog
DFW
I'm about to take it to my local hot rod place and tell them, I want it lowered. Hopefully they can do it all using stock parts(other than a flip kit of need be). So icy, yours are pretty much upside down, but still on top of the axle?
HemiBabe
DFW
Well... if you're wanting to use all stock parts you can always cut the springs. But I'm not sure about the leaf spring ordeal. I would just use a flip kit, but it's up to you. If you look around hard enough you can always find used lowering kits for sale... that's how I got mine.
rambob
LA/MS
318 5.2l
back in the day, the cheap way was to remove a leaf from the pack.
