Help looking for a lift
[email protected]
Hey guys i want to put a lift in my truck. I am thinking 4 inch. Not sure what band to go with. Can anyone help.
Rustproofcorn
6.7 diesel
Love bds personally.
blackbeautyhemi
Lewistown, PA
I know everyone bashes rough country but mine has been great for the 4.5 years and 30k miles it's been on my truck. Had no issues installing either, only complaint is the ****** rear shocks it came with but I switched them out with bilstein 5100's which I have at all 4 corners now and the ride is great!
derekp
Buda, Tx
1990 5.9 Cummins
Is your truck 2wd or 4wd?
derekp
Buda, Tx
1990 5.9 Cummins
What's your budget?
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
BDS would be the best option you can look at. The step down from there would be Zone or Superlift. What you end up going with will partially depend on what you want to spend.
17's should work with the lift provided you have the correct wheel specs to clear the suspension components. You'll need to read the details of the lift kit that you purchase to see those requirements.
