03MopaRamman
RAM SPORT / 18 SRT
- Jul 3, 2010
- 3,580
- 186
- Southern Alberta
- 2019 (2003 Forgottens SOLD and 2014 SOLD)
- Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
Since I'm Too Busy and got a great deal on install, Tommorrow (FRI) My Toasted Springs that are tired from Previous Owner abuse are finally gonna be sorted and keeping in mind future RCD Lift Kit end state.
As you can see from the Pics they are tired indeed and the rubber Bushes are cracked and the leafs are even out of line with each other where the bottom 3rd spring meets the overloader Leaf.
IMG]http://i823.photobucket.com/albums/zz152/dodge-ram2/Leaf%20Spring%20Changeout/2010-09-08144317.jpg[/IMG]
So what is being done.
First Install HD springs which are 4 +1 leaf and 2054 Lb Load Rating versis stock 3 + 1 1700 Lb. Part # is HD 3145 BTW. These new springs should add approx 2" of lift and will eliminate the need for future Fab-Tech add a leaf when I get my Lift Kit from PerformanceLifts.com. The leaf springs come with a longer center alignement Bolt.
2nd. I am Picking up 2 x new shackles at the dealer which come with that upper frame bushing and the bolt with blade stopper nut (as I call it) similar to those used as upper Shock fastener.
3rd. Although I would love the Bilstein Option available with future lift-kit purchase I wanna keep the freight cost down so I am Having a Pair of Rancho RS5000's installed with Red Boots.
I want my rear suspension to be in good order when I do my gears in the next few months and plan on removing Chrome diff cvr (last pic above) and adding a Mopar Orange painted one with mopar Chrome Bolts and finish it off with Helwig sway Bar.
This weekend I will post up pics of the finished job and fingers crossed there are no snags as it is a pretty straightforward procedure.
Been in the field all week and have been reading all the good threads ya'all been posting.
