Yeah another bilstein question
SFD213
I have a 2004 2500HD 4wd w/stock suspension. Am i able to just throw two bils up front to level and call it a day, or would that be unadvisable/impossible/unlikely?
usaf2006
Augusta, GA
The 2500 has coils on the SFA right? The Bilsteins level with the struts on our IFS trucks.
Do correct me if I'm wrong. It's late and I just slammed out a biology test :crazy:
SFD213
SFD213
Yeah i wana say they do. Like you said its late, long day at work, early morning tomorrow. Any normal day and id have an answer for you but i cant think straight. Ill double check tomorrow but i do believe theyre coil overs on the axle behind all the fun steering components and stuff
blackbeautyhemi
Lewistown, PA
You can get 5100's for your truck but I don't think they level like the IFS trucks, you'll have to get leveling coils or coil spring spacers.
SFD213
SFD213
Crap. Would throwing leveling coils on stock shocks over extend the shocks? Probably should just throw the shocks and coils on together
usaf2006
Augusta, GA
It shouldn't since its only 1.5 -2". But since you're in there, as long as they're not new, I'd change the shocks anyways.
SFD213
SFD213
Thanks guys. When i get home from work today im gonna do some 'splorin on the interweb for more stuff to spend money on now lol
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
Yup, as the other guys have said your truck doesn't have front struts so the Bilstein level is not an option for you. Your options are either leveling coils or leveling spacers. With either one you will want longer shocks and an adjustable track bar as well.
SFD213
SFD213
Wow this is turning out to be more of a project than i thought
blackbeautyhemi
Lewistown, PA
I'd still suggest adding the bilsteins tho while you're in there cause they ride great and have a lifetime warranty so why not?
SFD213
SFD213
Shop quoted $780 spacers and bils installed. HA! Yeah okay! Parts cost $280, ill do it myself
SFD213
SFD213
Ive heard the metal spacers are a bit of a rough ride. Looked at some leveling coils today. Anyone have any opinions on which one to use? I was looking at rough country because theyre cheap, yet at the same time im hesitant because, well, its RC, theyre cheap
NWRQC
Thuren or Carli. They cost a little more but you get what you pay for.
I went from spacers to the Thuren soft rate coils and it's night and day difference. With the spacers you will feel every crack in the road.
You have to remove the shocks to get the springs out, so you may as well replace them while you're there. Fox or bilsteins, you cant go wrong. You'll soon be looking for sway bar end links, as the stock ones will bend in no time, if they haven't already.
SFD213
SFD213
The thurens say theyll give me 4" of lift which is nearly twice the amount to level. Personally i think carli is a little expensive for a level, but not too expensive for lifts, so if i lift im going carli, otherwise im gonna stay away
SFD213
SFD213
Any opinions on the rancho set ups?
Edit: Disregard. Everything is for diesels. Apparently hemis dont exist in 2500s
NWRQC
They make a 2" soft rate coil that will give you about 2.5" of lift, which would be level.
SFD213
SFD213
The smallest i see is a 3" soft rate. Did they get rid of the 2" maybe?
