HID Radio Interference
Trupiano
Registered User
6.7L CTD
So a while back I ordered/installed a set of 5000K HID's for my headlights and fog lights. Worked great, and I was so excited how perfectly the installation and operation went until... Weedahoe told me to turn them on and try my radio. Needless to say, I have an ass-load of radio interference now on FM channels when I turn the HID's on. Not sure what the problem could be, but from what Ive heard/researched it could be either : Ground problem, or RF interference. I heard a bunch of people try and upgrade they're grounds with no success. Couple people said to try these to block the Rf interference :
Ferrite Core 1/4" Cord Noise Suppressor | Parts-Express.com
Well I tried 8 of them on various power and ground wires on the HID ballast kit, but nothing helped. I did notice while trying this, that with my head/fog lights on and radio going, the interference got weaker when I touched the wires. Not sure what that means... ground problem?
Now I heard to try one of these so I ordered both. Suppose to help with altenator/spark plug noise, and a couple kids said it helped with their HID problem, so I ordered them and Ill check them out next week.
http://www.parts-express.com/wizard...e=main&WebPage_ID=3&searchFilter=noise+filter
Also heard to try and wire the ballasts with a relay and a ground straight to the frame, instead of the plug and play harness I have right now, so I might try this later. If anyone has any input/tips/opinion please let me know. I wanna figure this out. By the way, got the 2 kits from HID extra. Im gonna call them monday and see if they have an ideas.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
wrap 'em in tin foil? :D (I am 50% kidding here)
donjohnk
Syracuse
I had a similar issue, one day I got a new set of HIDs and they came with double sided tape so I put it between the frame and ballast and now I dont have any issues. I did that same thing to a buddies Ram that had same problem and it worked also.. give it a shot.
Trupiano
Trupiano
Registered User
6.7L CTD
No **** huh! So he had the same problem and you guys just double sided tape'd them to the frame and it went away? I gotta try this! What kinda tape? Like 3M?
donjohnk
Syracuse
yep. i mounted my ballasts on the frame next to the radiator. used decent zip ties to hold em up and good to go!
AWE Daniel
Banned
yeah I have my ballast stuck in the gap above the headlights with the 3M tape and never had issues ever. I bet you used those mounting things they came with didnt you?
Trupiano
Trupiano
Registered User
6.7L CTD
Well my headlights ballasts are mounted above the headlight, sounds like the same place you have yours. Yeah I did use the mounts they came with, but Im not using them anymore. And I just mounted the fogs on the frame itself with 3m tape and a zip tie. But nonetheless, there's no change. Still staticy Do you have the same plug and play system from HID-Extra? Any more ideas? Im calling HID-extra tomorrow!
AWE Daniel
Banned
Yup but I have the slim ballasts. I've had both but never had a problem. One thing you could try is to ground the radio directly to the frame. Lot of work though.
Trupiano
Trupiano
Registered User
6.7L CTD
How exactly would I do that? Do you mean splice into the ballast harness's and ground them to the frame? Or just the radio? Thanks for the help by the way. This is really starting to **** me off! Why is it only 1 in like 7 people have this problem?
AWE Daniel
Banned
No I mean ground the radio. Find you radios ground wire and run it to a spot actually on the frame.
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Does sound like a ground issue. Double check all your grounds. Straps from the body to the frame and the grounds for the ballasts. When you touch the wires and it goes away tells me something isn't grounded right.
AWE Daniel
Banned
Yeah the stock radio ground location is most likely grounded to the body, which is bolted to the frame but has those rubber things inbetween, so the ground isnt always Ideal. Do you have an aftermarkertradio trup?
AWE Daniel
Banned
ohh btw admins this is in the 4th gen section just a heads up there
Trupiano
Trupiano
Registered User
6.7L CTD
Nothing worked lol, HID Extra never returned my call. So I guess Ill put up with it untill I can buy quality ballasts. From what Ive heard/read, it's the ballasts themselves that make the interference, and only the cheap ones do it. It realy sucks!
Haven't tried checking the radio ground yet though, so that's still an option. Ill check that this weekend sometime.
