Srt hood malfunction.
PCA4208
Albuquerque, New Mexico
Well today I was racing my friend for a short 25 roll. I don't think we even got to 50 then I saw something fly off from the front of my truck. So I pull over and sure enough it was the insert in my SRT-10 hood. Luckily it flew off and landed in a grassy median, paint up. No scratches or anything! So now I'm stuck with a huge hole in my hood until I figure out how to re attach this. What happened is that the clips that hold it into the hood at the front, sheared off the insert. So has anybody dealt with this before? And how did you fix it?
HemiLonestar
MD
Unfortunately it is a **** poor design for attaching it. Two of mine broke, but I was able to use screws up from underneath to hold it in place. Maybe epoxy something to act like a screw? I wouldn't trust it, I would start looking for a replacement. Sucks because new ones are like $240 last time I looked.
Christ, it's worse than that....
SRT 10 Dodge Truck Hood Scoop Insert Complete Kit New Mopar | eBay
This is just the bezel itself
moparonlineparts.com
MOLDING-HOOD
Make: Dodge | New Part#: YL23TZZAB
List Price: $342.00
Your Price: $235.75
PCA4208
PCA4208
Crap, that's what I was dreading. So could I get those pins that sheared off, plastic weld them back on, then use a bit of threaded rod in the four locating pins, and use that to bolt it on? I really don't feel like getting a new one, then having it painted and all.
HemiBabe
DFW
Oh man, that sucks!
Mine was barely hanging on by a thread too, I had a local shop plastic weld them back on, and so far it's worked pretty good
PCA4208
PCA4208
Yeah. That's what I'm picking up tonight. And some threaded rod. I'll show you guys what I'm thinking of doing in a bit.
PCA4208
PCA4208
Alright epoxy is setting. Me and my dad decided to run a bead of silicon sealant around the perimeter of the insert. He has some pretty serious stuff that holds our aluminum sink in place, so I'll do that too.
MegaMouseGW
South Louisianna
SRT 10 Viper Motor and Tranny
That is one reason I went with an aftermarket hood for my truck when I had to replace the motor. It is a true ram air style that actually works to force air into the intake. Here is a link to where I got the one I have:
https://www.ramairhood.com/store/scripts/prodView.asp?idproduct=40#
I also got their airbox which mounts right on top of the intake and connects directly to the throttle body.
devans
Rhode island
You know I saw this thread yesterday but I don't remember seeing the pictures so I didn't quite understand what you were talking about.
I really hope the epoxy works but I don't think so, if it doesn't work then look at the piece and see if there is "ABS" molded in the part. If so then you're in luck because you can chemically weld them back on. You will need something called Ambroid Pro-weld. Go to a good hobby shop, they should have it. This stuff will literally melt the two pieces of plastic back together so go easy on how much you use. Put the pieces together and using a toothpick drizzle the chemical over the seam. It will wick in through capillary action.
I build models as a hobby and use it alot. I also used it to repair a grille I got off of CL for dirt cheap because it had two cracks. Now it's good as new.
Silicon sealant around the perimeter is a good idea. It will give it a bit more hold.
Good luck.
Don
PCA4208
PCA4208
The insert says ABS+PC on it in the middle. The stuff I'm using is a plastic epoxy. I sanded down both mating surfaces to ensure it got good grip.
I have uses that type of stuff before on models. Also I used a similar chemical to weld plexiglass together. It works good. But I wouldn't trust it to the insert. When I used it on models, most time I could easily pry it apart with little effort.
I'm also going to be trimming these down and epoxying in some threaded rod so that it can bolt it down to the hood. Needless to say, when I'm done with it, this ***** ain't coming off! Haha
Ruiner
Alberta
Cummins
You do realize that this is the perfect time to create a new custom mod. Put a 6"-8" LED light in there. If I had a sport hood I would've done it to those "vents".
PCA4208
PCA4208
Yeah I want to start as soon as possible. What color should I do behind the insert and grille? I was thinking blue.
Ruiner
Alberta
Cummins
I wouldn't recommend blue unless you plan to use it only when stationary. Might get some heat from the police.
PCA4208
PCA4208
In that case I'll do flashing blue and red haha. No, I'll usually only turn them on while I'm parked.
Ruiner
Alberta
Cummins
Ok, then blue is safe. I was thinking more functional than show. White LED hidden in the hood. Sharp night light.
PCA4208
PCA4208
Who says I can't do both? Haha
Epoxy is setting on the threaded rod. So I'll be bolting it down, and putting silicon around the edges.
Goodie1990
