LS5DodgeRam
- Feb 17, 2013
- 793
- 115
- South Florida
- 2004
- 4.7L v8
Whats up guys? long time since I've been on and a lot has changed!
so I installed a Kenwood Dnx69s into my truck. I had 4 wires dangling out of my dashboard and it got very annoying so i decided to fix this problem. i had a a DOnor dash for a project i was doing before the doublew din, and it had the passenger airbag block off plate. i have a 2 door so i have the airbag switch. I relocated it and designed a hub that would hold all my USB, HDMI, and Auxillary cables. here is the fabrication and paint for it!
i cut the holes to fit each bit very snug
once fit i painted it, i went with a black base and a heavy colorshift metallic
then i started mounting the Aux and HDMI, then later the USB and JB welded the crap out of it. it is sturdy as hell!!
this portion of my dashboard is complete!
364903[/ATTACH]
as you can see from the pictures above i already JB welded the Autometer Cubby Gauge Mount tht Metra Double Din radio bezel.
next i took the bezel out and started applying and shaping the bondo to make it look like a solid molded piece.
sanded the whole bezel to get the rubberized coating off it and prep it for paint
Adhesion promoter is on
Completely primed
Sprayed on a guide coat to help straight cut the primer!
the molded contour
completely straight primed part
Sprayed on the black
i didnt get a shot of the metallic mid coat (it was going to rain so i wanted to finish asap)
but i laid on the clear coat and here is the final product!!!
Sorry in adavcne for the long post! but this is the step by step process of my interior
364903[/ATTACH]
Completely primed
the molded contour
