Little panel removal???
pajeepman
SE PA
5.9 magnum
Does this the little panel below the vent shown just pop out or ???? I want to put a dual USB outlet in it. Have not had time to look into removal, thought I would post up here.
Sent from my SM-J320P using Tapatalk
Core-Lokt
Texas
2005 Ram 2500 4X4 ST
5.7L
It's screwed on from the back; easy to remove once the whole panel is off. There will be a harness socket for a passenger air bag switch stuck in it-just tape the end and re-locate as necessary. I used that blank insert for heated seat controls.
Goodie1990
