2002 ram 1500 4.7 blown head gasket
mantis300
I found and engine from a Durango a little older with same vin do you guys think I may have problems doing the swap.7b012fa9c4631af1287b76d674549e4d.jpg15724922f14e2cb9baaa31d84db115b2.jpg
Sent from my SAMSUNG-SM-J727A using Tapatalk
Tach_tech
5.7L HEMI
Why not just fix the engine you have? If it was me, that’s what I’d do, instead of installing a used engine when you don’t know the history of its maintenance or how it was treated.
mantis300
mantis300
The one in the pic has 186,000 miles the new one has 115,000
Tach_tech
5.7L HEMI
Even then, for all you know it’s been a rough 115,000 miles. It could suffer the same fate.
The amount of work spent swapping motors is gonna be just involved as replacing a couple headgaskets.
mantis300
mantis300
The one that's in it has 186,000 and the used has 115,000. So if I rebuild what I have, it still has 186,000 miles along with the tranz . The engine I'm getti g comes with the trans and transfer case for 1,500 bucks already pulled.
Tach_tech
5.7L HEMI
Ok well that wasn’t in your original post. It’s still a gamble with used components but at that price it’s not a bad deal.
mantis300
mantis300
Yes could be, but I would have 2 of each to put one motor together. One already out and another in. I can work on the one before removing the old? Let's just say I take the time to remove the heads. It's possible the heads are warped or the block is cracked. If that's the case. I have a second motor to pull from. how much are new heads?
mantis300
mantis300
Im thinking at 75,000 miles the same fate could be worth it.
Jared26
Should be ok as long as the engine is from 99-03 starting in 04 they changed from a 16 tooth reluctor ring to a 32 which would give you issues unless you swapped it over.
mantis300
mantis300
Ok, the Durango I'm getting it out of is a 2000.
fastf
Georgia
2005 Ram 1500 Quad Cab SLT Thunder road
I would fix the old engine you already know something about the old engine.I would have it checked out while the heads are off.
Jems007
