Is there more to it then simply unplugging the old one and replacing it? Or do wires need switched around?
Well 03's don't use EGR and only have one cat. So besides getting rid of the TCM and repinning the connector to trans spot on the newer PCM, you have to decide if you're gonna go catless and write the O2's completely out of a custom tune and whether you're going to add EGR or write that out too. If you don't wanna write out the O2's then you have to add that to the harness. Then there's the whole thing of making sure the 05 PCM is flashed correctly; my truck doesn't have SKIM (chip key) but there's a good possibility that the 05 PCM I have is factory programmed with it so I'd have to have it reflashed to a program without it. If I'm not mistaken the cruise control is the PCM and if the donor PCM came out of a truck that didn't have it yours won't either unless it's flashed in.
