Floor shifter
kay9
Banned
xxxx
xxxx
The only reason i am getting it is the single gear up/down shifting without the chance of going into N.
This plus setting my shift light to 6500+ rpm should help with consistency..."should" anyway.
Hemiguy0302
Edmonton Alberta Canada
6.2 Boss
I don't care for that at all. It looks like a giant shoebox.
Very much agreed. If people want a manual shifting auto so bad then just run an adapter plate and a GM 4L85E. 2 birds one stone. A better trans and unlimited tuning abilities when a standalone is used.
truckin151
2013 sport
I agree with you there, but I have seen some very nice looking setups using this shifter as well. The center console really makes it either look really nice or like ****.
truckin151
2013 sport
The only issue with doing this is the trans will still be computer controlled correct? It wont be like a traditional shifter the where it hits what gear you want when you want it, it would still have a delay between 1-2 shifts and up and then not allow a sever down shift right?
The only real reason I have seen people do this mods is for 1/4 mile times at the track instead of shifting using the colum shifter. I would think you could set it up with a manual trans and use it as the shifter but for the automatics it will only do what the colum shifter will... just a little easier
RubberFrog
Hemiramon22s had a nice setup with the b&m.
Goodie1990
