2004 SLT 4.7 Need some help. I have the unfortunate exhaust leak tap noise from the dreaded manifold bolts snapping off. Since I need to put in a new bolts should I go headers and weld bungs to them for the sensors ? Or does that mess with the truck and give me a CEL. The truck only has 80 k so yeah I don't mind putting some money into it. Not looking to go dual outlet either. Any suggestions on products and vendors for a cheap fix or high end would be appreciated. I live it the rust belt so the Y pipe will be shot once I mess with it a bit. Thanks in advance
