EWC88
I want to change my plugs soon because it is in need of it. At the same time I want to give the engine bay a real good detail since that is in need as well, problem though. When I had my truck get a new radiator put in, some coolant got on engine bay so the guy hosed it down with water to clean it off. Well when I went to pick it up I noticed my check engine light came on, it was do to water getting into one of the plugs. Now after awhile of driving it dried the water up and problem was solve. But I do not want this to happen again as I feel it's bad, so is there anything else I should change with plugs to seal it properly?
