blackbeautyhemi
- May 19, 2013
- 2,190
- 1,314
- Lewistown, PA
- 2015
- 5.7 HEMI
Alright looking to see if anyone has experienced this or know why mine is doing this, but when I ease into the throttle or go up a grade when my truck is in overdrive and it goes to kick down a gear it shifts and then there's a thud that jolts the whole truck. It shifts up through all the gears smoothly and when you apply full throttle it kicks down smooth and shifts fine. This only occurs on a normal downshift out of overdrive. Today I got a code, P0734 - 4th gear incorrect ratio, my 4th gear still works and when I'm in tow/haul or od off mode it doesn't do it at all. Transmission fluid and level is fine, does it still when my tune is set back to stock, no broken tranny mounts, u joints seem fine. Any ideas?
