48RE trouble shifting into overdrive early
MrTunaCat
Hawaii
Cummins 5.9
Recently been having some trouble with my 5.9 cummins 48re. Sometimes when I am driving it will go 1st, 2nd, then overdrive…. Then kick down to like 3rd. Is my transmission failing? Or does a small piece need to be changed?
06 Dodge
Forest Grove, Oregon
6.7L CTD
IIRC its called Shuttle shift its been awhile since I owned my 06 with auto, IIRC you will need to replace either or both solenoid & transducer, have you tried doing a search for 48re Shuttle shift or just Shuttle shift on here or cumminsforum.com? Good luck
M
MrTunaCat
Hawaii
Cummins 5.9
I think it might be more than that. I tow/haul a lot and recently I have been getting stuck going up hill on having slow acceleration on flat ground. I am revving really high and barely moving sometimes. Almost like the brakes are stuck on then there will be a clunk that I can feel almost like the brakes came loose
huntergreen
Is there a line pressure sensor on your truck ?
06 Dodge
6.7L CTD
Ummm barely moving on flat ground suggest rebuild time.. One of the best rebuild kits around for the 48re is from Gorend: https://goerend.com/
M
MrTunaCat
Hawaii
Cummins 5.9
I really want to know what is getting stuck then clunking. Is it the transmission? It happens occasionally. The more I drive and tow the more it happens
06 Dodge
6.7L CTD
And sadly the more you drive the more that gets wore out, tore up and the more it will cost to repair...
