Gecko
- Jan 26, 2014
- 451
- 72
- NJ
- 2004, 2004
- 5.7L Hemi, 8.3L V10
Just wanted to give an update as to how the TorqStorm supercharger install is going on my truck.
We started last weekend. After we had replaced my fuel pump we started on the supercharger install. We immediately ran into a problem. One of the first steps of the install is to remove the clutch fan. As some of you may know, this is a *****! There is a special tool you have to use or make and we weren't prepared for this. This sidelined the entire rest of the day.
Next day we started up again, this time with a couple new tools to try and get the clutch fan off. Luckily, the strap wrench we got worked and we were able to proceed. UNTIL the next step which is to mount the first support bracket. The EGR valve is in the way. The directions make no mention of what to do here. Because of this I had to order the EGR block of kit from Billet Tech. So we put everything back to the way it was and I ordered the part last Monday.
Part gets in, I drop the truck off at my buddy's place on Friday, plan is to do it over this next weekend.
Well the EGR block off plate is too big to fit with the mounter bracket so that doesn't work (but the piece for the intake manifold does so that's good). From our angle it looks like the mounting bracket may block off the EGR valve itself. But the only way to make this happen is to drill our own hole into the mounting bracket. So we did. And now it fits. I'll skip some of the other annoying stuff but we get everything bolted up. Head unit on, antifreeze reservoir moved, belt on and tightened.
I had a base tune installed on my predator from AJ (AJHemi as he's known on the LX forums) over at True Street Performance. This was just so the truck could run to be able to get it to the dyno for the actual tuning session.
I load the tune up and everything starts! YAY...or not...
The good news was that everything started right up. The bad news was I had an exhaust leak right at the EGR valve spot. We had hoped not to have this but then we kind of expected it too. The truck was also surging quite a bit and running pig rich with the tune. we decided to change the idle settings to see if this would help. It didn't change the richness at all but once the truck warmed up the idle did smooth out a bit. But it was still idling way to high for us to keep it that way. We decided to reset the idle to what it was originally at.
And here we ran into our next problem. And this one is all my fault...
I must have bumped the wire with my knee as the predator was writing the tune because it restarted the predator and would only let me load up my original backup tune. AND it deleted the supercharger base tune from the predator. So now my truck can't be turned on and its still not finished.
So here's the plan for this upcoming week. I've got to get AJ to email me the base tune so that I can get it put back on the truck just so we can move it out of the way for a few days. My buddy is ordering a few more EGR valve gaskets and we are going to stack them behind the mounting bracket (we already put one there to start with) and hopefully that should get rid of the exhaust leak. Next this will give us more time to mount the intercooler and figure out the piping for it before it gets tuned.
All in all TorqStorm's kit is made well but I don't think they did all of their research. I think once we get the exhaust leak fixed and the truck tuned properly that it will run just as well as any other supercharger though.
I'll report back once everything is figured out and I have more to update.
Here's a couple pics for what it looks like installed. I'll get some more once I'm done and it's daytime outside.
