RamFam
That's going to be a pain, but doable. I still need to get an antenna. I will probably just go with a Lil' Wil for now.
Sent from my XT1254 using Tapatalk
Cheers. After looking at the roof shots , i should have routed the coax fromt mag mount to rear brake light then window then along the black roof trim to the B pillar lol.Nice man those are the exact clips i was thinking!!
Does the end of your coax have a removable plug or is it fixed?
Ok so your ***** bigger than mine ( joking , maybe even in reality ) LOL [emoji2]Not tried my set up yet but i routed my coax behind the dash,under console,under seat and up behind it..When i wanna use it i just pull the ant out mount it on the roof via slideing rear window. ..
My radio is the sexy stryker 447hpc2....Antenna is a mag mounted sirio performer 5000 with lmr 240 coax upgrade...
Hpc2 is smaller than a cobra with ballz and more options and tuned with a ranger sr198 mic all done by mark sherman of fine tune cb..
Hpc2 is not a sideband radio but has huge freq range...
When i want sideband i jump in my big rig with my stryker 955..
That Sirio one was pulled off easily on that video I saw, the eastern block fella with the purple Lada car.
Would putting the aerial on roof via door work on our ram trucks?
Ill try again when the new antenna arrives Wednesday. Cant believe i spent that much on an aerial lol. Considering the cb was 28$. Lol
Sent from my SM-T819Y using Tapatalk
Nah mate, i dont remember the last time i went over 70mph, so that wont be an issue.You gotta remember that the whip was well past 90 before the mag moved..Just picked up my whip for my sirio so ill be testing it out in a day or two...Unless your doin 180 mph i doubt your gonna have to worry...Even if you dont like that one use a pl259 type adapter and get a tri mag..
Another roof mount idea....This would be my only other option over "EVERY" other option but i dont wanna be cuttin holes in my trk..https://www.youtube.com/watch?v=LBEVwzo53J8
Bigger dik...Awww with a hunny like the one in your avatar,who tally wacker WOULDNT grow!!..lol
Ive got those harness loommcovers already, wanted a method like a junction box or something to connect multiple devices to truck battery cleanly. The bussman marine 6 or 12 input versions seems ok i read. But issue is gonna be making sure amp and cb is off before leaving truck else ill run the battery dry on truck. Thus thinking perhaps a switch also.Well it may look a bit messy but its the best way to power your stuff..To make it look better under the hood just use wire loom..Something like this.https://www.google.ca/search?q=wire...loom&tbm=shop&spd=9037292444652566906....Heck i have seen guys use colored stuff to dress up the coolant hoses and pwr steering n such with this stuff..
Ive been reading your posts on a couple of radio forums with interest, nice. Worlddx and radios reference forgot.?An ant can make or break ANY radio..So dont be cheap but be smart..
k0bg.com
