Chrysler 8.4 RA3/RA3 in a Ram
Chop413
Alabama
Has anyone used a 8.4 uconnect RA3 or RA4 out of a 2015 Chrysler 200 or 300 in a Ram 1500?
Ricks Ram
I know some guys have had problems in the past with Chrysler radios. I would recommend trying to get one out of a Ram if possible. If not out of a Ram the Cherokee also seems to work ok.
Mpgrimm2
SC
2022 Ram 1500 (5th Gen)
5.7L
Chop413
Chop413
Alabama
I got information from another site saying that it would work as long as it was from a 2015 and up. I found a really good deal on one, RA3 and bought it before you guys replied, lol. I should have it in 3 or 4 days and I'll try it out just to check. Thanks...
dtlasic
Please be careful. Those radios mount slightly, yet, significantly differently. You'll need to modify the radio frame by grinding off the top aluminum tab and remove two tabs from the radio bezel to make it fit. The wiring harnesses work.
The BIG problem....I tried a 2017 Chrysler 200 in my Ram for the same reason, it was cheaper. I did the mounting mods which I wasn't crazy about. Then came the problems.
The back up camera picture would go split screen into two pics split horizontally. The picture was not smooth. That is, it was staggered in play as though you were streaming a series of still pics.
Then the instrument cluster did some weird things like the display would light up on its own and stay on awhile. I was afraid it wouldn't shut off.
All other features worked great.
But, due to the problems I outlined I ended up taking it out and replacing it with a 2016 RAM version. Both radios were the RA4 Nav units. Now, EVERYTHING is fine. I wish I had seen your posting a bit sooner to help you avoid the hassle I went through.
I ended up selling the Chrysler radio at a small loss.
Chop413
Chop413
Alabama
Thanks for sharing all your issues with it! I only paid $140 for the RA3. I'll just sell it and maybe even make a few dollars.
dtlasic
I sold my 2017 RA4 for $550 on eBay
Chop413
Chop413
Alabama
UPDATE:
I got the 2015 Chrysler 200 8.4 VP3 that I ordered a few weeks ago. I immediately had to find out if it was going to work or not. All the wiring plugs matched perfectly with no issues! After the second time of turning it on and off the screen switched from Chrysler to the Ram logo. I got my anti theft code and everything works as it should, no problems at all and it's been two weeks now. The only thing that is different is the mounting points but it's a easy fix, all I had to do was cut off the plastic top center mount and only the two top side mounting points lined up, not a big deal and still very well secured. Just so others know it can easily be done!
Rock$tar
Newfoundland, Canada
Cummins 6.7L
Wondering will the 2016 one fit. Since it's a totally different unit. Has a capacitive touch screen , Android auto , and apple car play.
Sent from my Nexus 5X using Tapatalk
Rock$tar
Cummins 6.7L
