I know this topic has come up on several different occasions but I haven't found a definite answer yet. I want to change out my dual headlight assemblies for aftermarket quad assemblies. I've read that it is just plugged and play but I also read that that don't work properly. Some people say that when you go from duals to quads when you turn on your brights only one headlight will stay on, unlike the proper way, which is they would both come on; the low beams and the high beam. I also read that the daytime running lights won't work properly either.
So my question is: If I switch from stock duals without daytime running lights to aftermarket quads with daytime running lights will it work 100% properly with just plug and play? If not, how to a fix them to work 100% properly.
Any answers or suggestions will be much appreciated. Thanks!
