fiberglass sugestions
clays laramie
hemi
Never fiberglassed before, but i am thinking of sealing up my 1 -10 driverside fox box...cant stand the huffing coming out of the, obviously too small port on certain frequencies.. i am going to just try stuffing a sock in first to see how it sounds... but i was thinking if i am going to seal it i should pull off the stupid plastic bottom and use as a mold to make a fiberglassed bottom... i would assume this would increase the sound quality... any sugestions on fiber kits?? Also how difficult is it to do?? Thanks
baum
savage, mn
2015 Laramie
is it the factory enclosure or what?
if factory i would be leary about changing it as believe it or not its tuned for the sub.
now if its aftermarket you may be better off just making or buying a new sealed box that is to the specs of the sub
autokraftgt
Hemi 6.1
stuffing the vent with egg crate foam will silence your vent noise
clays laramie
clays laramie
hemi
I will try the egg crate stuff. Ethier way i bet a fiber bottom will sound better... my real question is can i use boat repair kits? Or do i need something special..??
charonblk07
Calgary, Ab
F1-A forged 349ci
Boat repair kits will work. I prefer a quality resin though and I'm only buying US Composite resin these days for fiberglass after using the Bondo repair brand for a short time.
baum
savage, mn
2015 Laramie
sorry when i first posted i didnt see the part that it was a foxbox.
the biggest downfall to this is the port will take up airspace from the sub.
i also agree to us composites. believe it or not resign has a shelf life and the stuff you get at home depot is usually at the end of its life since not a lot of it gets sold alot.
troutspinner
Gilbertsville, Pa
2019 Big Horn Crew Cab
Just a heads up. I've had emails back and fourth with the guy who makes the fox boxes and inquired why a sealed version was not available. His reply was that they never had any luck sealing those enclosures with sound quality.
Etroze86
Grand Forks ND
I think that's a horrible answer as it seems they would want both options, but I guess if they are trying to sell type r subs or whatever they are recommending now it makes sense.
troutspinner
Gilbertsville, Pa
I thought so also but it didn't stop me from buying an enclosure from them....so I guess it worked ;). But where is that box now....collecting dust in the basement.
clays laramie
clays laramie
hemi
Ya after using a sock for a bit i agree, sealed isnt better... im gonna try the egg cart foam.. im still gonna try to make a fiber bottom though when i get time....didnt notice that they were plastic when i ordered it.
clays laramie
clays laramie
hemi
DO you mean attatching it to the sides of the vent?? Glue?? Or just roll it up and push it in.. Autokraftgt
Goodie1990
