jejb
- Apr 7, 2020
- 1,578
- 1,448
- Location
- NW Arkansas
- 2022
- 6.7 Cummins
Max Car only provides rental up to 100,000 milesI don't defend anyone from a dealership, and I've had my share of bad ones.
Does the 169 point inspection specifically say that they're going to replace a cabin air filter? Those inspections are essentially safety inspections and general maintenance such as lube, brakes, tires, etc.. If something falls within spec, they leave it alone. If it's not on the list it doesn't get checked. I've NEVER seen ANY dealership replace a cabin air filter as part of their inspection. I've probably owned 50-60 vehicles of EVERY brand. Never happened once. Heck, it wasn't that long ago that Rams didn't even come with cabin filters.
The inspection does not require them to replace aftermarket exhaust components with factory components if it is functioning properly at the time. That is NOT a requirement to certify a vehicle. I'm sorry if you believe that it is, but maybe call the dealership and ask them. IF they have to replace a part, they replace it with a factory Ram part.
If the battery died the day after, why would you expect them to replace it? If they did, it would be as a courtesy but it is not a requirement. Again, if it tested good during the inspection and then sat on a lot for a period of time it happens. I would hardly blame that on a dealer.
How would suspension issues be caused by the dealer when they replaced the headers? (There's no service order posted that I can see) IF they inspected, found worn/loose components and adjusted them then yes.. you should be thankful.
Again... you said you purchased it a year prior to having this work done. If it's not under warranty, then they are under no requirement to help you.
You haven't answered a couple of basic questions:
1) Did the CPO truck come with a warranty? If yes, what specifically does that warranty cover? (BTW... Maxcare DOES allow for rental car reimbursement)
2) How many miles have you driven it between the time you bought it and the time you took it in for the suspension work?
I'm all for shotgun blasting a dealer who has done a shoddy job and just won't help but it really does look like the dealership did try to help. Don't take offense to what I am saying. I am just looking at what's been said and trying to look at this from both sides. We need more information.
How many miles were on the truck when you bought it?
Consider yourself lucky. The Ford/Lincoln dealer didn't provide us with a loaner when our Expedition crapped the bed (in warranty). They didn't have any to go around. We ended up paying for a rental out of pocket based on Ford saying they'd reimburse us. They did..... eventually. For half. We ate $1,400.FCA/Stellantis has always been non-committal when it comes to loaners unless you had a MaxCare warranty bought. Remember when I bout my 2015 Ram 2500 from one dealer, they had me sign a sheet specifically stating that I acknowledge that service loaners were not a guarantee.
Spent last Friday morning in my local Toyota dealership service department waiting on the Wife's vehicle to get serviced and it seemed they were handing out loaners like candy even if you were waiting on routine service. Pretty stark contrast to what my local CDJR dealer does that may shuttle you home at best if local.
Cabin air filters are not part of the inspection... See my earlier post.Cabin air filter should have been changed before it was sold, pre cert means it has been gone over , but sounds like it was not.
But that’s water under the bridge
My 2014 still has the original battery,
And come to think, everything else
Just rent a car
I have maxcare have you had to use it? I'm hoping they don't give me ****. My touch screen is acting up and freezing. My truck also is a certified pre-owned with a 3.5 inch rough country lift and after market exhaust. It's a 2020Do you have a MaxCare warranty? It covers rentals, even 1st day. If not, they have no obligation to supply you with a rental vehicle.
Nope, never a problem. Have it both on my Ram and Durango. If you want a rental while they work on it, make sure you give them plenty of notice you need one. There seems to be a major rental car shortage. The MaxCare coverage is for 35$ a day. My dealer has an agreement with Enterprise for that rate but some dealers don't and you would be responsible for anything over the 35$ limit.I have maxcare have you had to use it? I'm hoping they don't give me ****. My touch screen is acting up and freezing. My truck also is a certified pre-owned with a 3.5 inch rough country lift and after market exhaust. It's a 2020
And probably not even that. I'd guess most times a lot of boxes get checked that never actually got inspected.A tech is not going to do anything more than what the inspection checklist tells them to do.
See post #21 for the MaxCare on my 22 2500. It's $45 a day up to a max of $225. So the amount they will pay may vary, depending on when you bought the policy.The MaxCare coverage is for 35$ a day.
My take they did replace the battery and yes it is not certified pre owned. But I bought one once that was said to be certified but it was far from it. But since it a 17 and it is now2023. If they r still fixing it for free I would not argue about a loaner.Maybe "asking" isn't the proper term. More like "demanding" I guess.
Am I being the a-hole here?
Too Long Didn't Read Version: Truck was sold to me as "Certified Pre-Owned" but had aftermarket performance parts on it that have been causing me problems.
Long story:
In 2021 I bought a Certified Preowned 2017 Ram 1500 Sport.
The day after I brought it home, the battery died. I checked the battery, and it was the original oem battery that was sold with the vehicle. I called my salesman to see what he could do for me, he checked with the service department, and they said "sorry, we can't help you. This is a wear and tear issue." After blasting them on Google reviews and Facebook reviews, the salesman called me a few days later and said "look, can you take those reviews down? We'll reimburse you for the new battery." I agreed to do so as soon as the check cleared. I also checked the cabin air filter, and it was so full of dust it looked like a pillow.
A year later, I started getting the Hemi Tick. I brought it to a dealership - not the one I bought it from - and they informed me that the truck had aftermarket headers on it. Because of that, they refused to service the truck, and suggested I get in touch with the dealership where I purchased it.
I contact them, and explain all that's going on. They agreed that this is their issue. The dealership replaced the aftermarket headers with stock exhaust manifolds. I was given a courtesy vehicle for this.
Not too long after that, the truck's suspension was making rattling noises. It was getting so bad, I could feel the rattle through the pedals and steering wheel.
My thinking was that after installing the manifolds, they didn't tighten everything when reassembling the truck.
I contact the dealership again, and make an appointment.
I show up on the day of the appointment, wait in the line in the drive through, and I'm told to pull to the side and wait. After 15 minutes or so, I'm told that they were overbooked for the day, and that they set up a new appointment for me the next week.
I'm a little aggravated by this, but I understand that stuff happens.
The next week, they were able to fix the issue. The service order said "Installed 4318031AC Adhesive lock and seal. Found sway bar bushing, sway bar links, upper control arms, steering drive shaft loose. Tightened up all hardware related to suspension and steering."
So it was all good.
Fast forward to a few months ago, and the truck is starting to rattle again.
Also, there's a clicking noise in the steering wheel - similar to the clicking noise a steering wheel makes when turning with the turn signal on.
The exhaust has been making a chirping noise that's been getting progressively worse. (I recently discovered that the truck has aftermarket exhaust)
I've been super busy, so I haven't had the time to really deal with the dealership. Last month I called them to make an appointment. They can't see me until the 28th of September.
When I talked to the scheduling lady, I asked about getting a courtesy vehicle. I'm a busy person, and I'm often called to job sites at a moment's notice. I don't have anyone I can borrow a vehicle from.
She seemed very non-committal about them lending me a courtesy. "Oh i don't know. You know you have to have this type of insurance, and it has to be so-and-so type of situation." She then suggested that I rent a car and they may reimburse me.
So my next step is to call and talk to a manager.
Sorry about the long winded story. Basically, all the issues I've had with this truck stem from the fact that they sold me a Certified Pre-Owned with all kinds of aftermarket parts on it.
The fact that the battery was bad, the cabin air filter was filthy, the truck had aftermarket header on it, and I just discovered that it has aftermarket mufflers on it... it all means that they didn't certify a thing on this vehicle. Add to that the fact that I've had this truck for less than 2 years, and it has been to the service department 5 times dealing with these issues.
So, my question is, am I right to demand a courtesy vehicle from them? Any suggestions on how to go about it?
If it was sold as certified pre-owned and has the documentation, then it's a CPO. Why would you think otherwise? Certified doesn't mean that it won't break or ever have any problems. It just means that the vehicle meets pre-defined criteria at the time of inspection that Ram has put in place. That's about it.My take they did replace the battery and yes it is not certified pre owned. But I bought one once that was said to be certified but it was far from it. But since it a 17 and it is now2023. If they r still fixing it for free I would not argue about a loaner.
