I installed this MSW (modified sine wave) inverter under the hood. Mounted it to the fusebox cover with a 125A ANL fuse installed inline to protect the circuit. Only needed the 500W for my needs but I'm now considering installing a larger PSW (pure sine wave) inverter in the bed to power my lighting equipment on remote photo shoots.
Do not listen to anybody who tells you not to bother installing an in-line fuse or breaker. Ask any electrician worth his/her salt - the fuse IS important even if you are only occasionally plugging in your inverter. It is not there to protect the inverter but, rather, to protect the circuit from burning up and potentially setting your truck on fire. If the wiring gets chaffed and shorts against the frame somewhere, it will overload the thermal capacity of the wire which will cause the wire to heat up very quickly, melt its sheathing, potentially ignite the gases emitted by your battery (if the meltdown is close enough to the battery) and generally cause very bad things to happen. How do you think these cars you sometimes see engulfed in flames on the side of the highway get that way??? Don't waste your time building a great inverter setup only to skimp on the circuit protection. It's like taking a watergun to a forest fire.
