Coppertone
OK gents here goes, I know that several of you have been unhappy with the sound of your current system. I agree that it is lacking in several areas from a sq perspective. But with the correct processing done I believe that it can be improved upon readily. With that in mind I will be pulling my MS8 out of my Subaru and installing it in my Ram. My thought is this was designed to improve upon the OEM system using what is currently installed. Also it's a way for those to not have to give up any part of their sound system that they are still paying for in the truck payments. Yes this add on will not win you any sound quality contests that I am aware of, yet it will allow you more tonal control of your current system.
Also if at some point you decide to upgrade what you have, you still are able to use the MS8 in that equation. Progress reports to follow.
