VdubBry
- Mar 9, 2013
- 266
- 12
- 2013
- Hemi
Well after a couple of months of just a subwoofer ads on to the system I decided it just wasn't cutting it. So I had to upgrade.
Started with the JL Cleansweep (what an amazing piece of hardware this is)
Now I have a pure clean signal to send to my amplifier. I went with the Alpine 5 channel PDXV9. 100x4 and 500x1 to the sub. For the front doors I went with the Alpine type R 6x9 and the rear doors I used a set of Memphis Audio 2 way 6x9 that I had from a previous vehicle.
Ran all new speaker wire from the doors directly to the amplifier. All mounted with the clean sweep under the drivers seat. For the sub its a single 10" JL 10W3V3 under the passenger seat.
The sound is excellent! I am so surprised how well that Clean Sweep gives the amplifier such a good signal, you'd never know I'm running the factory deck. Way more volume which is what I needed as well, I am surprised at how much this truck rattles, especially the rear door panels, I can't believe how thin they are. I definitely will need to line them and the drivers door at a minimum.
I had ordered the Kicker 3.5" for the dash and planned to run them off the stock unit but they sounded awful, the stock 3.5" definitely had some sort of crossover/bass blocker on them and the Kicker didn't. It took away from the system. I don't think I'll need dash speakers because the Alpine 2 way 6x9 do a good job. Pics in the next post
