blackbetty14
- Oct 23, 2014
- 2,701
- 1,426
- CT
- 2024
- Hemi 5.7 VVT/Etorque
Budget is less than $130
This should hopefully be arriving this weekend: 12" Pinoneer TS-SW3002S4 Shallow sub
12" 4-ohm shallow subwoofer
mica-injected resin cone
power range: 100-400 watts RMS, PEAK Power 1500watts
frequency response: 20-125 Hz
sensitivity: 93 dB
mounting depth: 3-3/8"
sealed box volume: 0.5-1.0 cubic feet
ported box volume: 0.65-1.0 cubic feet
Im going to wait till next month to get a better amp but I have an old Jensen A46XP = 460watts 2/1 channel bridgable
170 RMS x 2 @ 2 ohms
230 RMS x 1 @ 4 ohms Bridged
This amp actually fits in them middle of the RMS rating which is nice but I think due to the system being a single 12" I should get it closer to 300-400w RMS.
I was looking at the Pioneer GM-8601 Class D mono Amp
mono subwoofer amplifier
300 watts RMS x 1 at 4 ohms (500 watts RMS x 1 at 2 ohms)
800 watts RMS x 1 at 1 ohm
CEA-2006 compliant
Class D amp technology
variable low-pass filter (40-240 Hz, 12 dB per octave)
wired remote controls variable bass boost (0-18 dB at 50 Hz)
preamp inputs and outputs
speaker-level inputs via supplied RCA-type adapters
fuse rating: 40A x 2
Im also looking at this cheap rockville which does 400w CEA RMS @ 4 ohm but also says 800w RMS @ 4ohm. But has a 1600w peak power at 4 ohm which is basically on par with the 1500w sub rating.
Rockville RXD-M2 3000 Watt/1500w RMS Mono Class D 1 Ohm Car Stereo AmplifierWith Optical Coupler Technology
CEA Compliant Power Ratings (Rated at less than 1 % distortion) (Use these CEAratings when matching and comparing with other CEA compliant brands such asKicker, Rockford Fosgate, etc)
1 Ohm: 750 Watts x 1 Channel <1% THD+N
2 Ohm: 550 Watts x 1 Channel <1% THD+N
4 Ohm: 400 Watts x 1 Channel <1% THD+N)
RMS Power Ratings: (Use these RMS ratings when comparing with great brands suchas Hifonics, Earthquake, Soundstream, etc)
1 Ohm: 1500 Watts x 1 Channel
2 Ohm: 1100 Watts x 1 Channel
4 Ohm: 800 Watts x 1 Channel
Peak: (The amount of power the amplifier can produce for a split second at theloudest part of a song
1 Ohm: 3000 Watts x 1 Channel
2 Ohm: 2200 Watts x 1 Channel
4 Ohm: 1600 Watts x 1 Channel
High-Speed MOSFET Power Supply
Optical Coupler Class D Technology
Studio-Grade Bipolar Output Stage Transistors
Now exclusively with Professional Peak Limiter Circuitry which guaranteesdistortion free musical playback at all levels.
Fully Adjustable 12dB / Octave Crossover with Differential Circuitry
Low Pass Filter: 50Hz - 250Hz
Subsonic Filter: 15Hz - 55Hz
Phase Control Switch
Full IC-Controlled Protection Circuitry
Remote Dashboard Subwoofer Control
Fully Adjustable 12dB Bass Equalizer
Mute and Delay Soft Start System
RCA Preamp Line Output
8 Volt Preamp Circuitry
Status Mode LED Indicator
Minimum THD at Rated Power: < 0.05%
S / N Ratio: > 100dB
Frequency Response: 10Hz - 500Hz
Damping Factor: > 250 @ 100Hz
Dual 40 Amp **** Fuse
Dimensions: (W x H x L) 8.5˝ x 1.8˝ x 13.7˝
sensitivity: 93 dB
CEA-2006 compliant
