What is this plug just hanging behind the grille on the front of my truck?
OnSale
5th Gen Crew
Philadelphia, Pa
Ive only owned this truck for 13 days and today was the first time ive taken the grille off to install Retrofit lights and I happened to notice this plug and I can't figure out what it's for.
Here is a couple pictures:
3ff8e21c5dc076c4a73a238521d8cfeb.jpg43cf3e8d89220855cfb00c8251094e2d.jpg839be17bfdedfe56380715d1f1eab363.jpg6622a752153e4a6045844778ceaa1845.jpg
Can anyone help me identify what this plug is for and why it is unplugged and just hanging on my truck? If it helps, my truck is a 2012 Regular Cab S/T 4x2.
Sent from hell via TapATalk
Jared4.7
Olathe, KS
2017 Bighorn CC
I would say its for the hood-pin switch that disables remote start when the hood is open. Truck probably already has that harness but the hood latch with the actual switch isnt installed.
OnSale
OnSale
5th Gen Crew
Philadelphia, Pa
Hmmm interesting. Why would Dodge/Chrysler install that on an ST model? Maybe the P.O. had a remote start and took it out before he sold it.
-B-
Northshore of Boston
why would they not have it there just to create more inventory streamlining have it there for all build instead of a special harness for trucks with out the remote start
OnSale
OnSale
5th Gen Crew
Philadelphia, Pa
I've got the same thing on my 2012 1500 4x4 BigHorn. I'm curious as to what it is also.
Well than, I shall ask the Ram Service Advisor the next time I'm at my local Ram service center. I will probably be going there next Tuesday or Wednesday to get a few things looked at/fixed that I noticed are "not right" on my "new" (to me) 12' Ram.
I'll make sure I remeber to come back to this post and let you know what he says it is. Maybe Jared4.7 is right and it's just the hood sensor for the remote start. It's highly unlikely, but maybe it's just a plug that's there for absolutely no reason (obviously kidding) ... who knows!
12sportmc
NC
It's for the remote start hood latch. It replaces the factory hood latch assembly when you add the OEM remote start and plugs into the latch. It's most likely there as a previous poster said, to streamline harness manufacturing. From what I've seen on the forum here most of the RC model Rams come prewired for everything you would be able to get in a top end model RC so that they only had to make one harness to cover all trim levels of the RC.
Razorbackfan
Orlando FL
Yup my 2011 had that and I added the factory remote start and it plugged right in. I had to take the truck to the dealer to install the win module and get the new keys programmed but I did that part of the install and it saved me a few bucks.
R.L.K.
Bristol , Tn.
Nice forum name !
Go Hogs beat Va Tech !
OnSale
OnSale
5th Gen Crew
Philadelphia, Pa
So my truck should have all the harnesses for stuff like the overhead display with the lights and stuff because right now I don't have anything on my roof except a roof liner [emoji53] and also it should have the harnesses for power heated seats and anything else a truck like an R/T would have??
12sportmc
NC
Theoretically, yes lol. One way to find out...pull the headliner down a little or take a look at the plugs under the seat. I do know it is way easier to MOD the 09-12s as far as getting things flashed from the dealers. CANBUS system wasn't as awesome (sarcasm) yet in those models. Before my wife totaled my 12 Sport I had added the OEM remote start and backup camera. Way easier than when I put it on my 14.
OnSale
OnSale
5th Gen Crew
Philadelphia, Pa
Yea I'm actually taking the seats out this weekend for something else. And wouldn't the harness for the overhead lights be wrapped up in the driverside A pillar instead of behind the roof liner?
Thanks for your help. Glad to know adding sales codes is easier in 09-12's
12sportmc
NC
Putting those seat covers on? Take your time and they'll turn out great. The disconnect is at the A pillar that's correct but the overhead harnesses themselves are molded into the headliner when they come off the line. Kinda sucks because you can't order a replacement harness without the headliner. I was able to source the connector I needed from a donor overhead when I added the rear window switch to mine for folding my mirrors. Do you have an overhead console at all or just the rear dome light? I think, not 100%, but if you have the dome light you should have the entire harness up there since it's a RC. Good luck
OnSale
OnSale
5th Gen Crew
Philadelphia, Pa
Yea I'm putting the Clazzio covers on. Being a RC there isn't enough room to maneuver behind the seats enough so I figure I'd just take em out to make it easier and quicker. My 06 Quad Cab I could have done it with the seats still in. But yea all I have is the light in the back and it's horrible having to turn the little wheel everytime I need light lol
Goodie1990
