Double Din Progress
Silverbullet08
Persona Non Grata
Well yesterday I decided to start on the double din.
First started cutting my dash
Next was the radio bezel
Then i test wired everything up. Everything was fine and it worked. awesome. put connectors on the wires and then tried it out. nothing. lost my power locks and overhead lights. turned out i blew the iod fuse. got a new one today and everything is fine. also got a 40amp relay instead of the 30amp i was using for the bypass.
brackets were some 1in l-shaped brackets i got at homedepot. they work but i need to trim them since the bottom ones cover the holes where the bezel needs to go in.
I still need to work on the bezel havent started on that. Just been messing with the radio. so far i love it. its awesome and pretty easy to use. oh my subs and amp arent working either dont know why. i plugged the wires in and got nothing so idk...
Laramie1997
Springfield, Missouri
1997 Ram/2013 Charger R/T Super Trak Pak
5.2 (318ci)/5.7 (345)
Question: Where is your remote wire hooked to? Do you have subs ON from the deck?
At any rate, I'm going to assume that the pics look good considering that my ISP is being rather ******** and I need to plant my boot in their ass in the morning.
Bad Habit
Land O Lakes
Modded 4.7l
Yup make sure they are powered up on the unit, as mine were switched off back when I bought my unit, took me a min to fig it out, yes I found it in the destructions, looking good tho nick keep up the good work
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
can't wait to see this done!
CaliDodgeRam
California
Thats legit man but ya just make sure they are on in the unit, i made that mistake for three days:confused:
4XLGATOR
CTD
Looks good, I've been wanting to do the same. And ditto on "what head unit is that"?
truckin151
2013 sport
I need to do something with mine soon, the stock volume knob doesn't work worth a **** anymore. Don't need anything fancy, just something run the subs off of
