HELP!!! Installation Of New Radio
cliftonclendenen
York, Pennsylvania
4.7L V8
I am trying to install a new radio for my 2006 SLT with 4 speakers. However, I do not know the things I am going to need to make it work properly. They have those bypass things for the factory amp, but I don't even know if I have a factory amp LOL!!! Anyways, I need to know what wiring harness I'll need because I've been looking around and can hardly find any information about it. Thanks in advance!
justin13703
MD
The xsvi-6502-nav should be the one you need if it's non amplified. If it is factory amplified there will be infinity badges on the doors up by the top of the door panel. If this is the case you will need a different harness.
You will also need the dash kit, and the antenna adapter.
cliftonclendenen
cliftonclendenen
York, Pennsylvania
4.7L V8
I thought you just buy the wiring harness and solder them to the new radio? Also this says its for navigation when I pull it up on amazon which I don't have?
justin13703
MD
It provides navigation outputs for if you are installing an aftermarket navigation radio. If you aren't then you just don't use these outputs.
And I don't really understand what you were asking with the first question. Yes you connect this new harness to the new radio harness but you still need a dash kit and an antenna adapter.
cliftonclendenen
cliftonclendenen
York, Pennsylvania
4.7L V8
Okay, will the PAC C2R-CHY4 work instead? I found a video about installation of a radio and he used this harness instead.
justin13703
MD
I'm not sure the only program I have uses metra products instead of PAC. From what I see though that PAC harness is more expensive than the metra one.
cliftonclendenen
cliftonclendenen
York, Pennsylvania
4.7L V8
Any way you can get me a link to the metra one? Preferably amazon. I have searchdd for it but i came up with 3 different types and i have no idea what kind to get.
Goodie1990
