Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Audio & Electronics
Audio & Electronics
Please Help!! What wire do i tap into for led bed lights??
This is a discussion on Please Help!! What wire do i tap into for led bed lights?? within the Audio & Electronics forums, part of the 3rd Gen : 2002 - 2008 category!
I'm trying to install led bed lights on my 2006 ram 1500 so I can see up under my tonneau ...
Like Tree3Likes
Reply
Old 11-15-2016, 03:31 PM   #1 (permalink)
OnSale's Avatar
Ram Year: 2012
Engine: Hemi 5.7L
Default Please Help!! What wire do i tap into for led bed lights??
I'm trying to install led bed lights on my 2006 ram 1500 so I can see up under my tonneau cover at night but I don't know what wires to tap into for a constant power.
If you could tell me what color wire on either the tail light harness or the 4 pin trailer harness I would really appreciate it.
Sponsored Ad
Register to remove this ad.
OnSale is offline   Reply With Quote
Old 11-15-2016, 03:35 PM   #2 (permalink)
Ram Year: 2014
Engine: 3.0
Default
Following
Superiorman01 is offline   Reply With Quote
Old 11-15-2016, 03:59 PM   #3 (permalink)
Ram Year: 2014
Engine: 3.6
Default
Should be the BROWN wire if you want to hook it to the 4 pin trailer harness to come on when you turn on your lights..... just googled "4 pin trailer wiring diagram".
stimpy433 is offline   Reply With Quote
Old 11-15-2016, 05:05 PM   #4 (permalink)
LB3711's Avatar
4th Gen Moderator
Ram Year: 2011
Engine: 5.7L Hemi
Send a message via AIM to LB3711 Send a message via Yahoo to LB3711
Default
I know Im the wrong year Ram but WHen I do mine I'm tapping off the cargo lamp. So when thats on Bed is on. Either by switch inside or automatically.
__________________
RamForum.com Moderator
New Here? Introduce yourself here - Click here to become a Supporting Member - Check out our Preferred Vendors!
2011 Dodge Ram 1500 QC Hemi Big Horn 4x4 -- Has Mods
LB3711 is offline   Reply With Quote
Old 11-15-2016, 08:16 PM   #5 (permalink)
OnSale's Avatar
Ram Year: 2012
Engine: Hemi 5.7L
Default
I don't want them on when I turn on my lights. I plan to install a rocker switch inline so I can turn the bed lights on and off without having to enter my truck or have my keys with me. I need a wire that's constantly drawing power, not one that only gets power once another switch is turned on.
I don't even want to go through the hassle of that wiring job. Besides, if I do it that way, I have to have my keys on me and flip the switch inside the cab. I want to hook it up so I can just flip a switch I install in the top corner of the bed.
Old 11-15-2016, 08:20 PM   #6 (permalink)
OnSale's Avatar
Ram Year: 2012
Engine: Hemi 5.7L
Default
Is this the 06 dodge ram wiring setup? If so, it looks like (if I'm correct, which I might not be, wiring is my weakness) it looks like I want to tap into the red wire, if I want to be able to turn the led lights on and off without having to do anything else.
Is this correct? The red wire in the 4 pin trailer harness is a constant 12v power line?
Old 11-15-2016, 09:16 PM   #7 (permalink)
Ram Year: 2002
Engine: 5.7
Default
There is no powerwire in a 4 pin. That diagram shows a 7 pin system. If you have the tow package, you may have a power wire there at the 7 blade.
Sent from my VS985 4G using Tapatalk
bulrid8 is offline   Reply With Quote
Old 11-15-2016, 09:18 PM   #8 (permalink)
Ram Year: 2002
Engine: 5.7
Default
I have a 12v outlet in my toolbox and a flashlight charger. I ran a 10ga fused lines from battery to toolbox for constant power. It is not hard to run a wire back to bed, from the battery.
akennedyusmc likes this.
Old 11-15-2016, 09:48 PM   #9 (permalink)
OnSale's Avatar
Ram Year: 2012
Engine: Hemi 5.7L
Default
I guess I'll just run one under the truck up to the front and into the engine bay and zip tie it up nice and hidden. I'll throw a fuse on it too close to the battery. Don't really have any other choice it seems.
I did see a YouTube video of a guy with a early 3g (04/05 style) and he cut into a constant power wire under his bed. He wasn't clear on what wire it was he just kinda said I cut into this wire here and never said the color and the video was too dark to see.
Someone has to have spliced into a wire back there for bed lights. I know every single person with bed lights did not wire them to their cargo light switch or run to the battery. I know many have wired into a constant, but it seems nobody is around to chime in and help.
BTW I have a 4 pin trailer harness. My truck did come with the tow package. Where would I find those wires? Is that the plug up under the little black "door" on the rear bumper by the plate?
Old 11-15-2016, 09:51 PM   #10 (permalink)
Ram Year: 2002
Engine: 5.7
Default
Yes, that is the 7 blade plug. Take a meter and test each pin with lights off. See if any are constant 12v.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
**How to wire flush mount reverse lights** 06ram15 Exterior 4 12-14-2015 08:34 PM
wire fog lights into parking lights hutchjoecraft Audio & Electronics 8 05-15-2015 10:43 PM
wire interior led lights to lights on power k1ng87 Interior 2 03-22-2015 07:59 PM
Puddle Lights Wire/Signal Diamond Exterior 2 07-29-2014 03:21 PM
How to wire reverse fog lights? DatacomGuy Audio & Electronics 14 05-22-2014 02:59 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
