where do i get a remote signal for an amplifier?
Ryan1126
San Diego, CA
5.7l hemi
im currently adding an amp and some subs in my 2019 bighorn level 2 without the upgraded system and am keeping the stock headunit so im using a PAC ANC-CH01 to bypass the ANC and pulled my signal from that to a Skar SKE2LOC but what setting do i need my trigger mode set to? DC and Audio mode work, but they wont turn off and i dont want my amp to drain my battery so i need a remote signal that will turn off when i turn the truck off, or is it normal for them to stay on for a long period of time after turning off? is there a wire on the PAC harness i can pull a remote signal from? is there a preferred spot in the fuse panel or truck where i can get a reliable remote source? i have done so much searching around google and i just cant find the answer im looking for, i really dont want to tap into a usb port in the center console or anything, i really just prefer to not cut into any of the stock wiring. i appreciate any and all help in advance.
Bucko72
New Mexico
F65 or f66 in the fuse box will work, I can't remember which one or maybe they both do.
Bucko72
New Mexico
Yes that is fine. The remote turn on draws very little voltage so an even smaller fuse will work.
