sub question
bigtigga84
dela....where?
So my friend came over the other night and we hooked up my subs to his truck. They came on and seemed to be working fine, but it almost sounded like they were blown. The subs are fusion power plants. I've had em for over five years and never had a single problem with them. They have been sitting for the last year when I took them out of my exploder. They are in a shared ported sub. Could they have been under powered or making the noise because they were in an open garage? Im really wanting to sell them cuz they are way too much for my truck but I don't wanna sell then if they are messed up.
bigtigga84
bigtigga84
dela....where?
by under powered i meant that the battery i had them hooked up too has been sitting for a year also. it's a stinger gel cell(i think). amp came on and the subs worked.
OklaHemi
new age hemi
man tyler i wish i could help bud. have you tried hooking them up to another power source?
bigtigga84
bigtigga84
dela....where?
lmao, i just pmed about this. he was only able to come over for a little bit. could it be the battery not having enough power? don't have anything in the ram to hook it too so no i haven't. and my the deck i had wouldn't even come on when i was trying to do it myself.
OklaHemi
new age hemi
pm responded
bigtigga84
bigtigga84
dela....where?
the amp
subs
one piece of wire bridged at amp to subs
specs on subs
FPW-1200
12" Sub Woofer - DVC 900 Watts Max
FUSION PowerPlant extreme excursion woofers utilise double magnet structures, die cast aluminuim baskets and superior performance dual voice coils to produce huge power and massive bass. PowerPlant woofers produce more than generous bass from even the smallest enclosures.
Product Specifications
Magnet Structure: 200 Oz
Power Handling (MAX): 900 Watts
Voice Coil: 2.5" Black Alloy DVC
Impedance: 4 Ohms
Free Space Response (Fs): 28.5 Hz
Efficiency (1W/1M): 94.5dB
Frequency Response: 22Hz-1.2kHz
Mounting Diameter: 11.22" / 285mm
Mounting Depth: 5.82" / 148mm
Outside Diameter: 12.56" / 319mm
specs on amp
FP-600D
1 Channel D-Class Linkable Amplifier
CEA 2006 Rated
1 Ohm / 2 Ohm Stable Linked
CEA 2006 Amplifier Power Standard Compliant
FUSION Regulated Amplifier Technology (F.R.A.T)
FUSION Intercooled Semi-conductor Technology (F.I.S.T)
FUTRANZ Efficient Heat Sink Transfer Technology
Gold Plated 4 gauge Power and Ground Connections
Gold Plated Audio Input and Output Connections
Gold Plated RCA Output for Multi-purpose installations
Compatible with FUSION bass control remote
Bandwidth 10Hz – 250kHz
Signal to Noise >95dB
Fuse Rating 2 x 30A
Separation >60dB
Input Sensitivity 300mV-8V
LP Variable Crossover 40 Hz – 240Hz @ 24 dB / octave
Variable Bass Boost 0dB + - 12dB Gain @ 45 Hz
Variable Sub Sonic Filter 10 Hz – 50Hz
Input Impedance 20KΩ
Damping Factor >200
T.H.D 0.05%
Dimensions D 57.5mm L 360mm H 220mm
CEA 2006 Compliant Amplifier Ratings
12.6 Volt Power Output Specifications
250 WRMS per Channel @ 4 Ohms and ≤ 1% THD+N
400 WRMS per Channel @ 2 Ohms and ≤ 1% THD+N
550 WRMS Bridged Channels @ 4 Ohms and ≤ 1% THD+N
14.4 Volt Power Output Specifications
325 WRMS per Channel @ 4 Ohms and ≤ 1% THD+N
550 WRMS per Channel @ 2 Ohms and ≤ 1% THD+N
700 WRMS Bridged Channels @ 4 Ohms and ≤ 1% THD+N
Linked Power Ratings @ 14.4VDC
1150 Watts RMS Linked @ 4 Ohms
1550 Watts RMS Linked @ 2 Ohms
OklaHemi
new age hemi
well they look wired right. you may check the jumper cables inside to make sure one hasnt come loose. what battery did you hook them up on? the amp needs 14.4 volts to operate at what its rated for and that is what your alt puts out. just running my system with my truck off and my acc on i am only pulling 12 votls from the battery so if the batery you are using isnt fully charged or going bad you may not be pushing hardly any power to the amp.
how high was the gain set , and the sub controls, and base controls on the hu set? did you have a hp or lp filter running? sorry for the questions there is just so much tweaking on theses things now days
bigtigga84
bigtigga84
dela....where?
The gain is cranked, place I got em said that it wouldn't blow em. I use to pound the **** out of em and never had a problem when they were installed. I did pull both speakers and check the wires inside, they we fine. Im thinking the battery doesn't have the charge it should, had em hooked to the stinger that's been sitting for a year. When I pulled them out I was suprise how shallow they were. Haven't seen them out since they were put in the box. Got a feelin they were makin noise became they were gavin into the garage. Not having a vehicle handy to put them in to test them sucks
brendo99
