Limeybastard
- Jul 25, 2015
- 1,872
- 449
- 2015
- Hemi 5.7
Well I couldn't find my original post which showed the tranny weeping oil from approx 800 miles when it was noted. Last time I checked and cleaned the drip around the seal was almost 10k miles ago. Currently almost at 20k miles and just looked under and clearly still see it weeping oil from the tranny main seal.
Originally thought it was perhaps manufacturer residue etc. But clearly not ?
Question, do I attempt them to repair this under warranty or just utilize the 100k engine and tranny warranty that I have should it mess up and loose fluid by then? I'm thinking the leak is so minute that I doubt it'll ever get low to damage the tranny but who knows. Pics I just took now attached below.
Also both my front wheel bearing seals are leaking. I had noticed this at around 8k miles and took pics of the gray colored grease residue around back of both front wheel hubs. Cleaned them up and now whatever grease that was left is covered the hub again. So both front hubs need changing . Funnily still no play in front wheels.
http://cloud.tapatalk.com/s/5796db6a6d8b1/20160725_233032.jpg
http://cloud.tapatalk.com/s/5796db9f9cd68/20160725_232059.jpg
Sent from my SM-G928T using Tapatalk
