you could just run your wire to the head light fuse that should work
Yes I have a wiring diagram ... Just picked up a set of smoked fogs. I have to copy and post the sheet for ya ...... it is wired with a switch ....... gimee a few.
Jim
i ended up wiring through there fuse box using the key only outlet for power. so if i forget to turn the switch off it will shot off when the key is out
Jim
I know this post is a couple months old, but Jim, if you still have this diagram, I could really use it.
are you planning on adding fogs? If so you can pick up the factory fog wire jumper for about $45 bucks I have a factory switch w/fogs and a set of the mopar fogs w/mounting hardware that come with the mopar fog light kit that I could sell for about $75 plus cost of shipping. ]
