rear lights HELP
whiteram1500
Tucson AZ
none of my tali lights or third light are working can someone please help it would be greatly appreciated.
Hootbro
U.S. Army Veteran
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
No magic pill here. Check fuses and common connection points. May need to find a schematic and go from there.
If electrical troubleshooting is not your thing, find a friend or family member that can help you as most advice on the internet will have you stabbing at when a methodical process from front to back is needed.
Hemi395
Cape Cod MA
Check the brake light switch right above the brake pedal. If that switch goes bad you will have those exact symptoms...
johnbradshow
99 ram 2500 with 5.9 24 valve
I think it's the fuse, otherwise, some of them should work, not all of them
