NOTW
2005 Dodge Ram 1500 Car Alarm Wiring Diagram
Battery Constant 12v+ Positive Wire (+): Red
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Pink/White
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Pink/Green
Second Ignition Positive Wire Location: Ignition Switch Harness
Third Ignition Positive Wire (+): Pink/Light Green
Third Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Blue (This wire must be energized during remote start to prevent the ABS light from coming on.)
Accessory Positive Wire Location: Ignition Switch Harness
Second Accessory Positive Wire (+): Pink/Yellow (This wire will turn on the ABS light if not powered up for remote start.)
Second Accessory Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Yellow
Starter Positive Wire Location: Ignition Switch Harness
Second Starter Positive Wire (+): N/A
Second Starter Positive Wire Location: N/A
Key Sense Wire: Violet/Tan
Key Sense Wire Location: Ignition Switch Harness
Parking Light Negative Wire (-): N/A
Parking Light Negative Wire Location: N/A
Parking Lights Positive Wire (+): White/Green
Parking Lights Positive Wire Location: At Under Hood Fuse Box
Power Door Lock Negative Wire (-): Violet/Green (860 ohms for lock, use relays)
Power Door Lock Negative Wire Location: At Driver Kick Panel
Power Door Unlock Negative Wire (-): Violet/Green
Power Door Unlock Negative Wire Location: At Driver Kick Panel
Door Trigger Negative Wire (-): You must diode isolate all triggers to cover all doors.
Door Trigger Negative Wire Location: At Each Door
Dome Light Supervision Wire (-): Yellow/Blue
Dome Light Supervision Wire Location: At Driver A-Pillar
Hood Trigger Negative Wire (-): N/A
Hood Trigger Negative Wire Location: N/A
Trunk Trigger Negative Wire (-): N/A
Trunk Trigger Negative Wire Location: N/A
Sliding Power Door Wire: N/A
Sliding Power Door Wire Location: N/A
Horn Negative Wire (-): Green/Violet
Horn Negative Wire Location: At Steering Column Harness
Brake Light Positive Wire (+): White/Tan
Brake Light Positive Wire Location: At Switch Above the Brake Pedal
Factory Alarm Disarm Wire (-): N/A
Factory Alarm Disarm Wire Location: N/A
Factory Anti-Theft System: Daimler Sentry Key Vehicle Immobilizer
Factory Anti-Theft System Type: Key Sends a RF Signal to the BCM Module
The 2005 Dodge Ram 1500 alarm wire color and location information above is updated as it is submitted by the Modified Life community.
