OutkastBoss
- Sep 16, 2014
- 11
- 3
- 1998 and 2004
- 5.9L and 5.7L Hemi
I have worked on vehicles before but do not have much Ram specific experience. I am talking about a 2004 Ram 2500 4wd with the 5.7 Hemi that we use at work and to tow Jeeps sometimes.
The motor and Trans were overheated and badly damaged by an employee, It was overworked on a job while our dump tuck was getting the motor rebuilt. It was a costly mistake and it now has a new motor and trans in it. The shop also had to take it back and redo it a second time because the new motor overheated as well.
About a week after we got it back again it developed an exhaust leak or leak at the manifolds that is pretty significant. The shop says the manifolds are warped and want way too much to replace them. It runs great otherwise so we ordered new manifolds, gaskets and bolts on our own.
We are going to do it ourselves, do you guys have any tips or specific approach or torque specs you need to do the job of swapping in new manifolds properly? It was all recently apart so hopefully we aren't dealing with broken bolts, but I will still do some Pb blaster soaks on the bolts.
I found this video that seemed like it would be very helpful to use as a rough guide but it is a Dakota and I am not sure how different the Ram layout would be. I was not able to find any clear walkthroughs or videos with a Ram in them but I am hoping I can go in through the fender and it will be built similarly.
https://www.youtube.com/watch?v=bQYpCJ6OmS4
Anyway t.i.a. for any insight you can share, like if I may need to get an odd sized socket or torx or inverted torx type crap I find myself needing on my Jeeps.
