ORANG3SALAMAND3R
- May 15, 2016
- 3
- 0
- 98
- 5.2L 318
Got this truck a couple weeks ago, went to change spark plugs and plug came out but not the threads. So ordered all new rocker arms, push rods, exhaust manifold, heads, head bolts, gaskets, thermostat and some hoses. Go through and replace all of the parts and truck has a crank no start issue with no fuel pump running (unless relay is jumped out), and no spark in any cylinder. Truck was running before I took it apart and rebuilt it. All connectors are hooked back up and all grounds are hooked up, All fuses good. Hooked up an obd2 scanner and scanner cannot make connection. Any help would be much appreciated in getting this piece running.
