Cruise Control
D.Schantz
My cruise control on a 2000 Dodge Ram (5.2) will not come on. Is there a fuse, link or breaker that can be replaced? If there is I can't find it. Looking for ideas, or suggestions.
Thank you ahead of time.
Neo299
Magnum 5.2
On a 2000 I believe that is controlled by a vacuum line. On my 98 my cruise control doesn't work because my vacuum line broke off so I just plugged it with a tiny screw. Find the cruise control module and follow the vacuum line. On my truck it is right under the battery box.
crazzywolfie
under the truck
have you first tested to see if there is power at the cruise control servo? with the cruise control on there should be power at 1 of the wires on the cruise control servo connector. i am not 100% sure but i think most of the time when cruise control stops working it is usually the servo is stuck or a broken vacuum line
D
D.Schantz
Thanks everyone. I'll check after church if it isn't raining. Right now it looks like it will be.
Nealuss
5.2L 318
Just in case you haven't solved this issue (or for anyone else lurking) be sure to check your brake light switch too. In some cars it will keep the cruise from working as a failsafe. Not sure about these trucks, though.
crazzywolfie
under the truck
and if you checked for power at the servo you would know whether or not the brake switch is the issue or not since the power travels through the brake switch first then to the servo.
safetyfast
1996 Laramie SLT 4x4 Club Cab
This. My line was really brittle and cracked. Replaced and cruise control works fine.
9th
Tallahassee, Florida
Check also if there's a recall on that...I read somewhere here but not sure the year model.
