My cruise control on a 2000 Dodge Ram (5.2) will not come on. Is there a fuse, link or breaker that can be replaced? If there is I can't find it. Looking for ideas, or suggestions.
Thank you ahead of time.
and if you checked for power at the servo you would know whether or not the brake switch is the issue or not since the power travels through the brake switch first then to the servo.Just in case you haven't solved this issue (or for anyone else lurking) be sure to check your brake light switch too. In some cars it will keep the cruise from working as a failsafe. Not sure about these trucks, though.
On a 2000 I believe that is controlled by a vacuum line. On my 98 my cruise control doesn't work because my vacuum line broke off so I just plugged it with a tiny screw. Find the cruise control module and follow the vacuum line. On my truck it is right under the battery box.
