I have a 2000 2500 4wd with the gas 5.9. I wanted to lift my truck 5 inches so i started looking up stuff to do it. A lot of the springs said they would fit 1500 and 2500 which doesnt make sense to me. So i went to a different forum to ask some questions and now im even more confused. I know that the 2500 rear springs are wider so they are different from the 1500 but the front is what is confusing me. They told me that the springs are the same height but have different rates. But how is a 2500 2in taller if they are the same height springs and if you put 2500 springs on a 1500 you get 2in lift? I understand on the diesel and big gas motor they would have a stiff rate for the heavy weight of engine but that doesnt make since on the v8. The 1500 and 2500 v8 have same motor and body so how is it 2in taller in front? If I put skyjacker 5in springs in front that both say lift 1500 and 2500 the same will they actually give me same amount? I also read that if you lift the 1500 offroad model package you actually get 2in less lift does that work the same on the 2500 gas 5.9?
I might be overlooking something but I dont just understand. So to make it short my 2 q's are how is the 2500 taller than a 1500 if the springs are the same so where does it get the extra height? frame im assumin? Also if I put 5in lift springs that say both fit 1500 and 2500 gas 5.9 will I get same lift amount or do I have to subtract?
Thanks I appreciate any help
- Tyler
- Tyler
